Learn how to troubleshoot using schematics like a real tech…
richt
Maytag Neptune Stacking Gas Dryer Model MLE2000AYH
4 posts in this topic
Hi,  I have a maytag neptune stacking gas dryer model MLE2000AYH which has stopped working - when you turn the dial to select the drying cycle I hear a noise that sounds to me a bit like a timer ticking.  When I push the start button it just makes a buzzing noise and the dryer does not turn on.  I tried to record the timer "clicking" noise but it is very faint.  the movie which is attached ( a .mov file which will play in quicktime) plays the sound of the buzzing noise when the start button is pushed.
maytag dryer.mov
Appreciate any advice you can give.
Thanks
Rich
Sounds like a frozen drive motor or a jammed belt or drum
did you remove the drive belt and try to spin the motor by hand ?
I haven't done anything yet as I really don't know much about dryers.  I've managed to make a number of appliance repairs over the years w/ the help of this forum but didn't want to start anything as I didn't know how big a deal it was to start taking thing apart.  Even if I can't fix it myself at least I can speak more intelligently to our repair person.  (I did pull the circuit board and re-soldered it on our Bosch dishwasher when the bad relay solder joint went so i am comfortable taking things apart to fix them if it's not too involved).
Think this is something I should try and tacke?
Thanks
