AlexM
U-Line Ice Maker, Model# BI-2115, could use service manual
15 posts in this topic
U-line Ice Maker, Model# BI2115, could use service manual and a clue.  Customer called and the refrerant systems is cooling o.k. and water is getting into the unit from the house, just not pumping water and or not making ice.  He said its the non-drain type of ice maker.  Thanks for any hints on what to look for.
This unit does not pump water , it's more like a household fridge the way it makes ice
the box gets cold and the ice maker freezes
the problem with these units most of the time is a small over heat fuse inside the icemaker
this fuse gets wet and falls apart
it can be checked with an ohm meter , most likely it's open
i am not sure you can even  buy one
most of the time it makes more sense to sell a new module
This makes sense.  I was all excitted to use the 'ice maker diagnosis flow chart' on page 2-3 of the manual and I couldn't get the ice maker to even harvest.  I tried pulling the tines forward and advancing the gear with a screw driver, no harvest. I had a heck of a time getting the ice maker out because the gummy stuff stuck to the bottom.  Once removed I checked for voltage at the wire harness and did get 120v across some pins. I have know idea what pins power what, but the ice maker was getting power somewhere.  Looking at the wire diagram on page 5-4 it looks to me like it could be the ice maker control (but possibly not, because i was getting power) or what you mentioned with the limit switch inside the module.  I'm leaning toward your diagnosis and am going to price a new ice maker for the customer.  thanks.
Well, I'm back with more questions. I installed the new ice maker unit and when I powered up it cycled and when it was time to fill with water, nothing. I checked the valve and looks like a bad valve, water to valve, lots of pressure.  Now I realize it was never the ice maker with the problem but the valve.  Here is my question, how do I cycle the stupid ice maker?  I tried the original one and the new one; tried advancing the gear clock wise with a screw driver, pulling the tines forward, no go. Am I missing something simple on how to get it to cycle? thanks.
Did you check with the service manual that Reg posted for you?
post a photo of the front of the ice maker , showing the gear (cover removed )
there are only 3 types out there
 as soon as we see it , most of us will know how this ice maker is advanced and you will have your answer
Edited by Cactus Bob
Attached is a sideways photo of the end of the ice maker.  I put the new valve in but over tightned the plastic compression nut on the valve, is there a special part number for those, different threads than copper or anything I had?  Also, I would still love to know how to cycle the ice maker....
post-71964-0-45798400-1357778224_thumb.j
a small flat head screwdriver in the little gear , it will turn only one way , it will make little clicks as it goes around .
if it is powered on , after you turn it a few turns it will take off on it's own and go through a cycle
if the little gear will not turn with a screwdriver (some do not )
remove the large gear
and move the tines that eject the ice slowly in the normal direction the motor would have driven them
when you reach a point the little gear will take off running , replace large gear (quickly)
and watch through a cycle
thanks a million!  can't wait to try it!
post-71964-0-47112200-1357927191_thumb.jpost-71964-0-22596300-1357927222_thumb.jI now need help finding the part number for the plastic compression fitting and feral.  Once i find it, I will order a bunch for van inventory.  Attached is the photo of the valve and nut. The valve P/N is 2552a.
AlexM : I can only guess that you don't do a lot of ice maker work
the next time you need a GE IM6 check the price on a whole kit it , it comes with water valve , ice tray and head . most of the time it's cheaper that the head alone
what you end up with after a few years is a whole bunch of water valves kicking around
all these valves are the same except for mounting
great to have for problems like this
another handy thing you can do . next time you go on a job where the ice maker is not hooked up , tell the owner you can remove it and give him more freezer space
A lot of the time he will say yes , put the ice maker in your truck , this will give you extra parts to use to test , play around with and learn from or sell to someone with little money for a new one
Start getting creative , and you will always have what you need
You are correct about the inexperience, I've been a general contractor the last 25 years and jumped into the appliance repair business with little to no training, not recommended.
I just opened up a IM6 kit and found a single valve but in most definately has a quick connect for the water line, not a threaded compression nut.  Is there some coupler to convert?
May I add,  the last 6 months, attempting to repair appliances, has been the most humbling  of experiences.  I marvel at the level of expertise you all have.  Everytime someone responds to my silly questions I'm very greatful and amazed, Thanks!
Oh man, It just dawned on me what your talking about...you mean to just use the single valve out of the IM6 and ditch the threaded one from Uline?!  I'm slow on the uptake...
Then I can use a brass ferel and nut in lue of of the gardan hose style feed?  The single valve is part number WR57X10033?  Thanks again.
post-71964-0-99113100-1357946985_thumb.j
