GE Model# WSLS1500J0WW
vee8power
Went out on a complaint of "GE washer not draining". Imagine my surprise when I saw a model# starting with WSLS.... I thought to myself...WTF! Is this an LG? I removed a thumb wheel from a lighter out of the pump. I thought all was well until I got a callback :yucky: .
Sounds like the rest of the lighter is between the tub and basket.Wanting to be more knowledgeable  when I go back, I searched "Downloads" with no luck. Can anybody help me with directions getting the machine apart?
sorry, I can't answer you questions,
but for reference
GE WSLS1500J0WW :woot:
SpaceMaker Portable
