Service manual and wiring diagram for Kenmore 596.62232200
drlabitzke
If a service manual and wiring diagram for a Kenmore bottom freezer refrigerator 596.62232200 could be provided, I'd be ever so grateful.
Thanks,  Dale
Kenmore 596.62232200 made by Amana
mechanical controls,
what's the problem ?
Freezer 60 deg, refrig 60 deg, defrost heater cold, evaporator cool to touch, compressor discharge warm to touch, compressor running (by touch), evaporator fan on, condensor fan on.  I think it lost the refigerant charge.
any frost on the Evaporator Coils ?
yes, post pictures ?
no, probably a leak $$$ if Compressor is running ...
No frost.  The coil is just cool to the touch, not cold.
Yep.  Probably a leak.  Yep, probably $$$$$.
if the Compressor is running and the Evaporator Coil is not getting frosted,
then either the Freon leaked out, somehow
OR the Compressor is bad..
either way $$$
TheApplianceGuy
Yeah $$$$ for my company. depending on the physical shape of the ref. itself,  I can usually sell a 5 to 6 hundred repair with a 1 year guarentee over the possible 1200 to as much as u could spend replacement.  I mean after all i know we all say,  "well, they dont build em like they use to".  And u said "freon", thats funny.
Edited by TheApplianceGuy
