New Appliance Service Manual added: Frigidaire Affinity Washer Door Sag Bulletin
File Name: Frigidaire Affinity Washer Door Sag Bulletin
File Submitter: Samurai Appliance Repair Man
File Submitted: 21 Jan 2013
File Category: Appliance Repair Manual Pot Luck Supper
SERVICE FLASH
Door Sags Slightly To Door Lock
Frigidaire
MODEL/SERIAL #
All Affinity washers prior to serial XC925xxxx or 4C950xxxx Models: ATFxxxxx, BAFWxxxxx, CFWxxxxx, DAFWxxxxx, FAFWxxxxx,
LAFWxxxxx and SATFxxxxx
PROBLEM: Door sags slightly (striker to door lock) when door is closing. Significant “play” in hinge to inner door.
SOLUTION: Shim the hinge using service kit p/n 137309800 ==> http://www.repairclinic.com/PartDetail/Door/137309800/1615173
Click here to download this file
  • Replies 0
