kenmore service manual request
these are two different washers.mine is a kenmore super capicity 3.5 quite tumble action wash.easy access.it has a program knob & a temp knob along with 6 push buttons.there is no cycle selector or lcd display.
Yeah, it's always tricky to cross a Kenmore model number over to it's OEM equivalent to it's usually kind of a best guess situation.  That manual should do for disassembly.  If you need diagnostic info, you should always use the tech sheet for that.
Remove the front panel below the door and it'll be in an envelope pasted to the inside cabinet wall... unless someone done stole it!
beer money on the way
Mucho domos, compadre!   :pint1:  :banana:
