Need serv manual for Subzero 680/s serial 1911733....plus any supplement manual if avail.
charliefoxtrot
charliefoxtrot
Need to troubleshoot why no ice and water come out of new dispenser I just put in...thanks.
  • Replies 5
  • charliefoxtrot
charliefoxtrot
Thanks, however I didnt see any sections on troubleshooting no ice/water thru door dispenser....is there another manual that covers this??
Thanks again!
This manual has dispenser component access info ==>  http://appliantology.org/files/file/645-sub-zero-refrigerator-600-series-service-manual-part-2/
For troubleshooting, you'll need to use the schematic on the tech sheet supplied with the unit or, if missing, you may be able to get by with the schematic in the manual that Reg linked you to.
... This manual has dispenser component access info ==>
I believe that has a different Dispenser ..
Maybe so but that's all the dispenser info I could find for this model.  Between the schematic and the parts breakdown in the manual that you linked, that should be sufficient for diagnosis.
CF, if you need more troubleshooting/repair help on this, start a new topic in the Kitchen Forum and we'll tear into it there.
