  • Announcements
      On-demand appliance repair training videos for Professional Appliantologist members Over 30 hours (and growing!) of original, high quality appliance training webinars developed and given by yours truly are at your fingertips, on topics you won't find anywhere else. Fill in those knowledge gaps, strengthen those areas of uncertainty, and boost your skills. Watch on mobile or desktop at your convenience whenever, wherever.  Ultra Short Primer on Basic Electricity, Circuits, Ohm's Law, and Schematic Reading (Length: 1:04:48) Basic Refrigerator Troubleshooting (Length: 1:10:45) Schematic Reading Workshop, 10/2015 (Length 1:19:08) Troubleshooting Strategies for Computer-Controlled Appliances (Length: 48:34) Semiconductors and PN Junctions (Length: 1:04:37) Appliance Temperature Sensing Devices & Technology (Length: 1:27:33) Voltage Measurements, Meters, Ghost Voltages, and Triac-controlled Neutrals (Length: 1:29:32) Troubleshooting with Tech Sheets, Part 1, 4/2016 (Length: 1:09:26) Troubleshooting with Tech Sheets, Part 2, 4/2016 (Length: 1:21:11) Tech Sheet Review, 4/9/2016: Bosch Speed Cooker, Amana Refrigerator, GE Glass Cooktop Range (Length: 1:22:58) Pulse Width Modulated (PWM) Switches used in Samsung Switched Mode Power Supplies (SMPS) (Length: 27:07) PWM Computer Cooling Fan in a Whirlpool Refrigerator (Length: 14:53) Understanding AC Split-phase Household Power Supplies (Length: 52:41) Troubleshooting a Samsung Electric Dryer without Disassembly using Live Tests and the Schematic (Length: 22:47) Troubleshooting a Bosch Dishwasher No-Heat Problem using the Schematic and Live Tests (Length: 15:38) Linear Motors and Linear Compressors (Length: 55:54) Bi-directional PSC Drive Motor Systems in Whirlpool VM Washers (Length: 56:52) Appliance Service Call Structure and Troubleshooting Strategies (Length: 1:00:16) The Ten Step Troubleshooting Tango and Workshop Exercises (Length: 1:35:39) Troubleshooting Ten-Step Tango Advanced Workshop (Length: 1:32:06) Ten-Step Tango Troubleshooting Workshop: Refrigerators (Length: 1:35:57) Whirlpool Duet Washer Schematic Analysis & Whirlpool Dryer Moisture Sensor System (Length: 1:03:04) Neutral Vs. Ground, Inverter Microwave, Digital Communications, Loading Down in DC loads, and more! (Length: 1:14:45) Gas Oven Service Call After a Parts Changing Monkey (Length: 36:04) AFCI and GFCI Circuit Protection Technology (Length: 41:26) Troubleshooting Samsung Refrigerators and more (Length: 1:29:58) 3-way Valves and Dual Evaporator Refrigerators (Length: 1:15:45) Split-Phase Compressors and PTC Start Devices (Length: 1:11:57) Gas Dryer Ignition Systems (Length: 53:50) Refrigerator Sealed System Thermodynamics, Part 1 (Length: 43:07) Refrigerator Sealed System Thermodynamics, Part 2 (Length: 1:09:09) Refrigerator Sealed System Thermodynamics, Part 3 (Length: 1:11:56) Refrigerator Sealed System Thermodynamics, Part 4 (Length: 37:45) Refrigerator Sealed System Thermodynamics, Part 5 (Length: 16:35) Appliantology Peer Group web meeting, Feb 25, 2018 (Length: 1:47:30) Appliantology March 2018 Peer Group Meeting (Length: 1:59:58) To access these webinars and all the other info-goodies here at Appliantology, become a Professional Appliantologist today. If you need cost-effective, time-flexible, state-of-the-art appliance technical training, check out the Master Samurai Tech Academy.
    • Son of Samurai
      [Webinar] Appliantology Peer Group   04/24/2018
      Bring something you'd like to share with your brethren in the craft: it could be photos, a tech tip, new insights gleaned from recent training -- anything having to do with the business or technical sides of the appliance repair trade. If you've got something to show, we'll let you share your screen and give you the opportunity to teach us all something new. And of course, Team Samurai will be there to answer any questions you might have about how to use Appliantology.
crosstalk
Evap coil cleaning (CD5AXA060024ABAA)
crosstalk
Hello.  I'm looking for some advice on my system and coil cleaning.  I have a carrier infinity system with coil model CD5AXA060024ABAA.  When I bought the house two years ago, I noticed that the electronic air cleaner was switched off.  The EAC prefilter was really dirty.  I just removed the EAC elements and replaced with a 4" media filter because EACs are too much work in my opinion.  Then I noticed the A-coil was freezing over.  I tired to clean the coil and called a technician out for repair.  He told me two things: (1) compressor was not original carrier and looked like it had been replaced; (2) the txv was an r-22 model and he replaced it with an r-410a model.  He suspected that the compressor had probably been replaced due to the incorrect expansion valve.  When he worked on the system to replace the txv (located just outside the evap coil enclosure), he couldn't get the all the refrigerant back into the condenser, so he had to add some (after replacing the valve of course).  Presumably the refrigerant charge was correct at that time.
Last year, I replaced the filter media.  AC was functioning normally.  In the winter, I noticed that the furnace high limit trips (according to the service mode event history on the infinity thermostat) if the return closest to the unit is blocked (toy box tends to move in front of it).
This year, the evap coil is freezing again.  I have this feeling that the underside of the coil is really dirty because the system could have been running for years without an effective filter.  The blower wheel was/is dirty too (tried to clean that with vacuum two years ago).  When I open the evap access panel, I don't have access to the end caps of the coil.  In other words, I am looking at the fins on one side.  My cleaning technique has consisted of spraying coil cleaner on the front and reaching over the top of the coil and spraying on the back as best I can.
Here are my questions.  If I remove more of the duct/evap casing so I have access to the end cap, will I be able to remove the end cap to clean the underside of the a-coil?  How else can this be done without pulling the coil?  Is cleaning from the top side likely to be enough?  I have an appt on wed. with another technician but would like to get some opinions on whether it would be worth pulling the coil to clean it.  Thanks for reading!
... EACs are too much work in my opinion.
... Then I noticed the A-coil was freezing over.
... In the winter, I noticed that the furnace high limit trips (according to the service mode event history on the infinity thermostat)
... I don't have access to the end caps of the coil.  In other words, I am looking at the fins on one side.
1) ? ?
2) completely frosted ?    OR just one area ?   may be an air-flow problem / filter / fan   pictures ?
3) may be an air-flow problem / filter / fan
4) pictures ?
crosstalk
(1) EAC- I tried to clean it and use it but wasn't sure it was working.
(2) The back side seems mostly frosted (by feel reaching over the top).  The front side that I can see is frosted in one section across the center.
I don't have pictures right now but can post some tonight.  Thanks.
KCTBURY
If I cant access the underside of the coils i get a garden hose in there and spray the coils through the top.
You may have a clogged capillary tube.
... If I cant access the underside of the coils i get a garden hose in there and spray the coils through the top.
may depend on where the Evaporator Coils are located ...
basement :thumbsup:
attic :woot:
living area  :woot:
crosstalk
The system is located basement.  I am afraid if I use a garden hose I am going to flood the whole unit.  Will the water be contained in the drip pan?
Bobice
This is an R22 Unit. Replacing the expansion valve is not the right thing to do as R410 is not compatable with the oils used in R22 systems.
Did he flush the coil and lines out ? Also list the numbers on the "Compressor and I can tell if it's a Carrier Compressor.
crosstalk
I don't have the condenser model written down.  Will get that later.  The condenser is labeled puron and the coil is labeled for either r-22 or r-410a.  The last tech also told me that compressor had been changed out at some point because it wasn't the exact model or genuine carrier part.
