Tech Manual for Model#FFUS2613LS0
Cityboysrus
This particular model has a certain sequence that has to be followed in order to reset the control panel. If I remember correctly the door has to be and closed followed by a key dance.
try this manual... discussion of your electronic control begins around page 29. http://appliantology.org/files/file/557-frigidaire-side-by-side-refrigerator-with-electronic-controls-2007/
For future reference , please provide the type of appliance as well as manufacturer. It saves us some time and helps with indexing. On top of this, manuals on frigidaire's site is organized by type and style of appliance and then by manufactured date, not by model number. It's a real pita since we have to read the manual to see if your model number is covered (although this particular manual gave no model numbers).
Make no mistake, we are very happy to provide you with what we can but a little help goes a long way. Thanks!
I didn't know Frigidare requires that. Will do. Thanks for the manual. :wallbash:
  • 9 years later...
I have a question. Clients refrigerator Fresh Food section light not working and bulb has been changed. I have not headed over yet and taking the light socket and the door switch. Looking at the wiring diagram on page 35 neutral goes to the supple wire goes to "apollo Lighting Control" what is apollo lighting control? it is not on the parts list/digram. where is the neutral wire connected for testing?
THANKS
