GE GSS201EPA SERVICE MANUAL NEEDED
philcheck
REF AIR DAMPER PROBLEMS==REF WARM FREZ OK PC,DAMPER AND THERMISTERS REPLACED..NO FROST BUILD UP ,GOOD FAN
  • Replies 5
  • philcheck
  • Spannerwrench
... PC, .... REPLACED.
did you cut the Thermistor wire in Pin 2 of J1, as mentioned in the MotherBoard installation instructions ?
What's the first (3) characters of the Fridge serial number ?
http://appliantology.org/files/file/267-ge-refrigerator-31-9071-arctica-knob-w-encoder-sxs/
THATS GOT TO BE IT....THE WORDING ON THE SHEET LEADS YOU TO BELIEVE THAT IT APPLIES ONLY TO "ALL BOTTOM FREEZER MODELS..WITH ENCODER MODELS WITH THE FOLLOWING SERIAL NUMBERS  ETC ETC ETC"  WHEN IN FACT ITS "ALL BOTTOM FREEZER MODELS  AND ALL OTHER ENCODERS MODELS WITH THE FOLLOWING SERIAL NUMBER"    UGH...DRIVES ME CRAZY!!! :woot:  :wacko:  :pint1:
There's only one instance which there needs to wires cut.
If the refrigerator main board is mounted vertically (as shown below), AND there are wires in both
pin 1 and pin 2 of J1, Cut the wire in J1 pin 2.
Note: When cutting the wire, leave enough wire to reconnect if necessary!
Taken from this pointer.
https://www.dropbox.com/s/m7s72q1o46d47ix/Main%20Board%20Replacement%20Pin2%20cutting%20jumper%20wire%20clipped%20Gss22%20gss25%20hss22%20hss25.pdf
Edited by Spannerwrench
