Utica boiler with Beckett AFG Series burner
jambatt
Utica boiler model # SFH 33100WTL with Beckett AFG Series oil burner model # 02117-90519 and Beckett Interrupted Ignition Oil Primary Control model # R7184B1032. Green flashing light indicates lockout condiition, however; control will not reset when reset button is pushed. Is it a bad control or an ongoing condition that must be addressed before control will reset?  Power to the control but no power to the burner motor.
  • jambatt
  • Cactus Bob
  • CvW
You should never just reset an oil burner , there was a reason the reset tripped in the first place
most likely your nozzle is plugged with a little dirt , or your transformer is not producing enough spark to light the oil
regardless of the reason , pressing the reset button (if it worked) may just pump another 45 seconds of oil into the chamber
I worked at a church 30 years ago in my new jersey days , the oil boiler was out , i asked the pastor the number of times he has hit the stack control(reset) , he said once , with that i pushed the button and flames came out of everywhere , up the flue out the front man what a jaw dropping mess
with that he said , i only pressed it once , but my wife might have been pressing it too
an oil burner is nothing to mess with if your unsure of what your doing
Edited by Cactus Bob
A few thoughts... first, clean the HX. All of it. Get a good brush, and a good vacuum. Make sure the thing is as clean as possible and that you got most of the gunk out. Then go down the check list.
An easy annual item is the nozzle - always replace and chuck, do not attempt to clean, drill, etc.
Electrodes can be adjusted to perfection with precision-ground go / no-go gauges.
The turbulator needs to be clean, devoid of soot, etc.
The external air supply shutter should be clog-free, adjusted per mfgr specs for the particular nozzle/model of burner. Ditto on the internal baffle, if there is one (Viessmann Vitoflames have 2, IIRC).
You should be using a tiger loop. It prevents condensation and water accumulation in oil tank by eliminating oil return line leading to warming and cooling inside heating oil tank.
Are the filter(s) clean? Don't use cheap filters, rather go for a quality filter that has a vacuum gauge built-in that shows whether the oil pump is straining to get oil into the burner - a sure sign of a clogged filter. I used to use Garber. Seemed to work as intended (kept water out of pump).
Ensure there is no water in the oil tank. If there is, find an opportunity to drain it out per federal/ state / local requirements. Water in the tank leads to bacterial growth, tank degradation (if you have an old-fashioned steel tank), etc. Water issues usually rear their heads when people run low on fuel or after fills when the tank is roiling. A floating pickup can help here.
Check the flue pipes and chimney for obstructions, clean as necessary. Double check draft damper for proper operation / installation. Ever find a racoon in a flue? An acquaintance did. Thank goodness the boiler refused to fire.
I'm sure there's more. Only after going through the whole check list listed in the service manual should you attempt to re-light. If you haven't taken the service course, do. It'll save you a lot of headaches.
After successful re-light ensure you have zero smoke (you are using a smoke meter right?) followed by using an electronic combustion analyzer to dial the air shutter(s) and / or oil pressure into perfection.
See OilTechTalk and the Firedragon forums for more specific advice re: tuning oil systems. Last I heard, both owners tour the country giving tuning / service seminars.
If you're not a pro, have a pro with the right equipment (i.e. smoke meter, electronic combustion analyzer, etc.) do it for you. Annually! Even though I am a certified service tech for the boiler I used to service in my home I still hired a pro annually to re-check it, etc.
Ever since I switched our house to gas heat, I have been looking forward to taking that service course too. Not enough time! But even if I were certified to service it, I'd still have a pro look at the thing annually.
Edited by CvW
