Kenmore 106.50592000 Fridge
BradE
Hey Durham,
I don't see the lighting board in this diagram. Do you know how power is routed through this board? Does 120 come into this board and then distribute to unit?
Thanks,
Brad
Hey Durham,
Yeah, i looked at it before I posted it and I did not see it neither. I thought it had more to do with my limited abilities at deciphering wiring diagrams. However, I did check the model for that particular tech sheet and it has the same boards as your model, including the lighting board. Maybe Sir Reg can enlighten us.....where's that page button when you need it??
... i looked at it before I posted it and I did not see it neither.
... Maybe Sir Reg can enlighten us.....
what's that thing on the wiring diagram called
"WATER FILTER INDICATOR" ?  :whistling:
uh.... is this one of those trick questions like "when was the war of 1812?" Ok.. ok... I'll take a stab at it... it's a hmmmm.. this is a hard one.... is it a Water Filter Indicator?? lol
And here I am thinking Hugh Grant is still alive. Silly me.
you must be thinking of Hugh Jorgan  :whistling:
