Frigidaire Refrigerator FRS6HF6JW0
Patricio
May I obtain a service manual & tech sheets for this Frigidaire I got a call on tonight about warm refrigerator/freezer compartments. Going to look at 10 am in morning. Not much more info other than it was emptied of contents & unplugged yesterday. I asked that it be plugged back in, forgot to tell them to set controls on middle settings.
Edited by DurhamAppliance
added a "J" to the model number in topic
http://appliantology.org/files/file/557-frigidaire-side-by-side-refrigerator-with-electronic-controls-2007/
if you obtain the manufacture date located on the model tag, you can easily find the manual. This model is a 2007 model. If you searched the download section for "Frigidaire 2007" you would have found it. For sxs fridges, Frigidaire has multi-model manuals for 1999, 2001, 04, 07,and 09. So models made in 2007-2008 would be covered in the 07 manual. They have one multi-model manual for french door fridges, one for bottom mount and one for their professional series. A couple of manuals along with technical sheets cover top mounts.
There should be rare situations to have a Frigidaire manual emergency like you are experiencing now as you should already have the correct manual in your dropbox, etc. If you don't have the manufacture date for their SxS fridges or top mounts , you can go to Frigidaire.com and look at the publication date on the owners manual for the model. The wiring diagram is also there.
Have not seen the unit or manufacturing label.  I did put Frigidaire & model number & drew a blank.  Learn something new every day here.   Thanks Duram you are as awesome as Reggie is.
Pat.   Here is the light bulb for the refrigerator if you need it.May want to pick up  a dozen.   :woot:     http://www.repairclinic.com/PartDetail/Light-Bulb/241555401/1056583?modelNumber=FRS6HF6JW0
Ugh,   Yea I'll get on it.
Edited by Patricio
