Maytag Range jes8850bab
arrow 1
  • Replies 4
  • arrow 1
  • electro_doc
That model number doesn't work for me.  Check it again.  maybe you could take a picture and post it.  Is your stove gas or electric, being you are looking for elements I would think it is gas.  They are usually easy to access so I'm guessing if yours are hard to access you may have the glass top stove with the elements under the glass.  If this is what you have then you should be able to take out screws in the front and I'm not sure but maybe some it the back too and lift the stove top off, disconnect quick connect harness and flip it over to work on it.  This may or may not help as I have no idea what your stove looks like.  good luck
well I don't know why but I couldn't get anything with that the 1st time.  Now I see however that you do need to remove the top to access the burners.  Should be no problem but now with the file it should be a breeze.  thanks to Reg!
