GE Advantium Model SCA2001BSS 03
Repromen
Does anyone have a schematic for this model. Its the 220v of the GE Advantium. Every thing comes on the fans timer light and the convection lamps. Only thing that doesn't work is the actual microwave. Any help would be great.
  • Replies 4
  • Wirenut78
  • Repromen
  • 2 years later...
1 hour ago, Wirenut78 said:
Anyone know what happened to the link?
Who knows but the file is still in the downloads and you can locate it using the PUB number Reg posted along with the link:
On 11/16/2013 at 5:20 PM, RegUS_PatOff said:
GE Advantium 220v 31-9038.pdf
To do this, take the part of the PUB number after the "-" and make a wild card search term like this: "*9038" Then search the Downloads using that term and you'll find it. Or you can find it using a model number search.
That PUB is the service manual. The minimanual, if you want that, is a different PUB. You can find it using a truncated model number/wild card search.
