Hank
Can cracked & leaking outer GE washer tub be epoxied?
4 posts in this topic
I have acquired a used GE washer Model # WCSR2070TBWW. The outer washer drum is made of a translucent plastic. Have any members successfully been able to use an epoxy to seal a crack in the external tub? Thanks !
Never had the nerve to try it.  The risk was too great.
You can probably get away with a tub and water seal for less that $75 in parts and a pretty big job for a DIYer.   You'll need a special spanner wrench also.
If it's a single speed machine don't bother.  If it's a two speed machine, not too old and in good shape, it might be worth it.  We can walk you through the job if you're up to it.
If I were to try to patch it I might foil tape a large portion outside the tub and epoxy the inside.  I find a business card spreads epoxy nicely.  Of course, don't do what I said and flood your house and say I told you to.
Thanks for your kind reply. Our neighbors were careless when they removed the washing machine from their house. The drum was not locked down and the lower bleach dispenser housing (mounted on the exterior drum) bashed against the side of the washing machine and caused cracking all around the flange of the bleach dispenser where it mates to the outer drum. I have decided not to epoxy the drum. If anyone on this website needs the parts I have salvaged from this washing machine, let me know.
That said. The GE machine above is an example of a machine built extremely simple and looks to be a throw away with the exception of the easily changed components like the pump or motor. My family uses a 1985 Kenmore Series 80 (built by Whirlpool). Still works great, is built like a tank and yes, I have done a few repairs to it over the years. But nothing last forever and I hope to educate myself on a reasonably priced replacement for the ol' Kenmore. Anyone's suggestions for an "affordably dependable" machine will get listened to.
Thanks everyone and especially Samurai and family !
Yep, that's GE fer ya.
Got a couple ideas ratcheer:
http://fixitnow.com/2005/02/is-there-washer-and-dryer-worth-buying.htm
http://fixitnow.com/2005/03/washing-machine-shootout-staber-vs.htm
Thanks, Hank!  Best to you and yours!
