Maytag washer MVWC300XW tech sheet please
auburntommy
  • auburntommy
So to clarify...I did a download search and found Tech Sheet - W10280489 which covers the washer MVWC400..... Looked like it would cover the MVWC300....but most of the error codes I got where not in the diagnostic matrix error code tables so I thought there might be a tech sheet that was different. I might have a problem with the control board however so not sure. Anyways I'm new to the forums so my apologies if this is the case. Thanks for a great website!!
MVWC300XW0
W10280489
MVWC300XW1
W10280489
MVWC300XW2
W10468340
Edited by RegUS_PatOff
