whirlpool gold oven gw395lepboo
montrue
Can anyone help whrilpool gold oven need tech sheet,oven will not work  no bake,broil,temp control but if you hit stop time +start bake will   heat to 350? (touch pad or main board)
  • Replies 1
  • montrue
Service manual:  http://appliantology.org/files/file/1573-whirlpool-self-cleaning-slide-in-gas-range-service-manual/
Tech sheet:  http://appliantology.org/files/file/1574-whirlpool-gw395lepb00-gas-range-tech-sheet/
You'll need to upgrade your membership to download them:  http://apprentice.appliantology.org/
Moving this to the Appliance Service Manual Request forum.
