Jenn Air Range JDS9860AAP
jambatt
  • Replies 5
  • jambatt
jambatt, you can help yourself and find what you need a lot sooner if you would just search the Downloads section.
Did you catch the part about the wild card searches?  Showed that in the screencast.  You mean you missed it?  How could you ignore my mellifluous voice? :dazzler:
Wild card search turned up service manual for dual fuel slide in range. Didn't have wiring diagram in service manual. :kopkrab:  Unit I'm dealing with is a free standing gas model.
Edited by jambatt
