Samsung Microwave SMH9187B SE error
homerettetx
homerettetx
Does the control pad fix the problem?  The control box is not longer available.
Don't want to buy the control pad if it doens't fix the SE code problem
Any help on this is appreciated.
  • Replies 1
  • Chat_in_FL
  • homerettetx
