Amer std and trane 10 year warranty
edwardh1
  • Replies 1
well well well, so you want to buy a trane, a trane and american standard is the same by the way , A trane unit is a very good unit, but keep in mind this if you are a do it yourselfer, If you buy a trane  and over time it breaks down say after the warranty has run out ,you wont be able to buy parts for it if you aint a trane dealer,a civilian wont be able to just walk in off the street and buy a trane part. most parts are specialized on trane units which means you will have to get your parts directly from them, you catch my drift ?
