SAMSUNG DRYER (DV400EWHDWR/AA)
applianceman1
Looking for service manual OR tech sheet
for this dryer.
There are some DV4* in the
downloads.
Not sure what is compatible with
this dryer.
Thanks
Did you look at the descriptions or download them to see which one covers your model or do you want us to do that for you, sire?
If you can't find one after you TRY.... let me know.
Edited by DurhamAppliance
No
I have several model number that are compatible
but none of them seam to be in the downloads here.
Thanks for any help.
did you reduce the search list by searching for.. say... "dv400*"?
That brings up one file..... download it and check it for compatibility
Also, if you search the dl section for "Samsung dryer".. you will get a long list.... in the list you will see a file that says something like Samsung dryer.. standard disassembly for multiple models. Download it, check it against your model's diagram at Searspartsdirect. If it looks similar then that manual will aid you in disassembly. That, along with the other manual should give you what you need.... remember, we have no magical knowledge and have to go through this procedure ourselves.... try it, learning search methods will definitely benefit you.
Yes
it brings up 406 and 408
not dv400ewhdwr/aa
no, it brings up a manual that covers dv4006 and dv4008....did you download it to see if your model is mentioned? Did you check to see it boards are the same?
Did you diw
This one is a little different animal... on the outside. Instead of the round glass door, it has the more conventional solid square door.
Uploaded the tech sheet just you, Walter: http://appliantology.org/files/file/2046-samsung-dv400ewhdwraa-dryer-tech-sheet/
Cool, and the Standard disassembly manual specifically covers the model....So you have a tech sheet and disassembly manual.....does sire demand anything else? lol
I want to thank the 2 of you for your help.
Durham thanks for all the information on using
the site.
I think that's it for tonight.
C U TOMORROW :)
You are preparing in Advance! , you even got your customer to send you a picture of the dryer! That's what I'm talkin 'bout! With that attitude, you will succeed and I will go out of my way to help you however I can... but that also includes giving you grief if I even suspect shortcuts! lol
