CAE2743BQ0 Coin Op Washer
ramwilkinson
Most likely a problem with the lid switch, the commercial washers won't do anything except turn on the cycle indicator lights if the lid isn't closed.
Replaced lid switch...same problem.
Check for proper polarity and a good ground at the wall outlet.
Do test #1, main control as described in the tech sheet. May need a new shifter or control.
Edited by vee8power
Does anyone have the service manual or tech sheet for this washer?
All the lights are on.
Haven't been over there yet looking for information.
look  for  a manual inside   frame  and   tub  should  find  all  u  need  there
when u  find  the  manual  u  will  have  to read  up on  resetting  it   .and  make  sure  u  have  water  coming into machine . both  hot  and  cold ,thats  all  i  can  say if u  figure  it  out   cheers
  • 4 months later...
  • 3 years later...
 I have a coin-op machine on which I just replaced the motor and control board because a motor bearing went out and the control board would not work after I replaced the motor. After replacing said parts, I could test the washer but it wouldn’t run a cycle after operating the coin slide switch and pressing start. I followed the tech sheet and performed every applicable test (which checked out) and still nothing. I removed the jumper wire on the interface control board that changes it from  “pay” to  “no pay” and was able to run a load that way. Do I need to replace the interface board or is there another issue? (I also tested the coin slide switch on another machine and it works fine and all my connections to the new main control board are connected and secure.)
Is your model number the same as this old topic? You may want to start your own topic with your model number and symptoms so we can keep separate topics separate- keep things organized.
