KITCHENAID Side-by-side Refrigerator Model: KSRS27IHBL02
Techonamission
Requesting service manual for KITCHENAID Side-by-side Refrigerator
Model: KSRS27IHBL02
Thanks
Did you try truncated searching using "Ksrs27*"... how bout widening the search to Ksrs2*? Find anything compatible? If you did not find anything compatible in the dl section, did you try truncated searching the entire site or specifically the Manual Request forum using "Ksrs27*" first then widening? Is what you find sufficiently compatible?
Searching in this manner can be very fruitful.... you may find tech sheets that are for a different size.. ie 25 cuft vs 27 cuft but everything else is the same... check it out... Secondly, by searching the entire site, you may find someone has requested a manual for a similar model and may point you to something you did not locate in the dl section. Also, by searching the site, you may just run across someone asking questions that may pertain to your issue.
Did you search " Kitchenaid SxS" in the dl section as well and checked out those manuals for compatibility? Sometimes things have been uploaded that may not specifically list individual model numbers
Find anything compatible? Let us know.
Edited by DurhamAppliance
