Older Kenmore stackable washer 110.1650290
Looking for a service manual, tech sheet or schematic or any info out there for a 19 year old Kenmore stackable washer 110.1650290. Haven't been able to pull anything up on this anywhere. Thanks in advance for your help.
  • SD40-2
  • Thirstytech
110 prefix indicates Whirlpool as the manufacturer, so it should be the same as any thin twin. What's the issue with it?
It is a Stylemaster 4213575REVD. Complaint of does not spin and does not seem to be agitating. Clothes wet when load finished. No unusual noises or odors. Options I'm planning on looking at are the door switch, coupling, possible drive belt if it has one, or maybe even a bad drive block. Not sure if it is direct drive. Any other ideas or recommendations. No info on this machine so going in blind. Thanks in advance for your help.
