KitchenAid Built in SxS Model KSSC48FMS03
KurbyMstr
In need of the service manual if available.  Found some posts with tech sheets that the links did not work.  Also found the page for the Wire Harness Connectors on the Gemini ES Main Control Board, which will help but would like the manual or tech sheets if available.  Thanks in advance.
Tech bundle here: http://appliantology.org/files/file/834-kitchenaid-refrigerator-kssc36fms02-technical-bundle/
And you'll want this service pointer: http://appliantology.org/files/file/2239-diagnosing-the-led-on-whirlpool-refrigerator-inverter-boards/
If those files with broken links are in the Downloads section, please post the link to the page with the broken links (URL in your browser address bar) so I can fix them.
Thank you for the response.  The homeowners are replacing the unit.  It's one of 4 homes they own.
