Coldstream commercial single door refrigerator unit only. no freezer
No model number. Only info I have on it is stainless steel, 23 1/2" wide X 30 1/2" deep X 85 1/2" high on 5" wheels. Not much out there on Coldstream so anything would be appreciated; tech sheets, schematics, service manuals. Thanks in advance!
looks something like pic below
post-95529-0-36583000-1436077983_thumb.j
  • SD40-2
Posted Images
Have you tried contacting ColdStream to see if they can get you service and tech info? Usually for commercial stuff, you get the tech literature directly from the manufacturer.
