Kenmore/Samsung M# 592-4908701
RiverviewAppliance
RiverviewAppliance
Hey I need the tech sheet and any other relevant information for this model, thanks.
  • Replies 4
  • RiverviewAppliance
  • Spannerwrench
If you can cross this over to a Samsung OEM model number equivalent using the techniques we've discussed previously, I can probably get a manual for you.
I think it may be a Kenmore Canadian model number.
