stupid free dryer
stupidfreezer
stupidfreezer
i am working on a maytag dryer model LDE 7500 and the only time it heats up is in auto dry, If i put it on time dry,it doesn't heat up, and in auto dry it heats up but doesn't shut off. Do i need a timer ir in of the thermostats?
  • Replies 9
  • stupidfreezer
    6
  • evaappliance
  • Thirstytech
stupidfreezer
by the way i fixed the stupid freezer it was the controls on the front. Got tyhat honey do off my list.
check your heating element to be sure it is not broke and grounded, I think on this model the time dry is air fluff only . very good old dryer so it is worth trying to fix .
see if you are getting power to the timer moter,  it will only have power to it when the element is cycled off.
stupidfreezer
it is getting power to the motor,what makes this dryer automatic? as far as i can tell the timed part is only for the air fluff
if it is getting power to the timer motor, but  it is not advancing the timer ,you have a bad timer
stupidfreezer
what makes it automatic in the more or less dry setting? i know the timer is part of it but is there a sensor as well?
stupidfreezer
it was the run thermostat it has five wires going to it. i went to reliable parts here in spokane paid 41 bucks and it works great now.
