LG Dishwasher LDS5040ST Error
Hobb
Our dishwasher worked fine yesterday and this evening when I went to start it there was a little snowflake icon blinking on it. I looked it up and some people said it had to do with the rinse aid. I checked and the rinse aid wasn't empty but I put some more in anyway and the problem persists. The snowflake icon will blink for a few minutes, then the whole thing shuts off. Any help would be great. Thanks.
  • Hobb
  • 16345Ed
  • Treydiggity
Check your user manual. Does this unit require the special salt?
i couldn't quickly locate a manual to check.
Nothing special required for the unit. At any rate, I hit some buttons, removed some of the detergent, played around and eventually it started. Hopefully it won't crap out on me again. Thank you for trying still :)
  • 3 years later...
Treydiggity
It seems that the door is not latching properly I backed the top mounting screws out a quarter of a turn like sone have advised but nothing then I gently lifted up on the front panel of the door and the thing started working
They should have a light for door not latched properly
