Viking vcbb363rss refrigerator
Amosjdg83
I have a Viking refrigerator model vcbb363rss.  The problem is the compressor is not turning on at all. I checked the inverter and it is bad. I took it apart and there was some brown fluid in there and one of the capacitors has exploded. The other capacitor has a pretty big bulge. Problem is the model number on the inverter is vcc3 1156 02a 03.  This inverter is not sold anymore.  Is there a new inverter that will replace it and if so part/model number?  Thanks in advance for your help!
  • Thirstytech
  • Spannerwrench
  • Amosjdg83
Post a picture of the decal on the inverter. You'll need a photo hosting site like photobucket to do it.
The original part number for the inverter is G5098300 which crosses to 011666-000. VIKING Distributing East has 35 in stock.
