GE Monogram ZISW420DRA freezer too cold fridge warm
WalterP12
Hello all,
I have been wrestling a GE Monogram ZISW420DRA side by side fridge for about 8 months now with the same problem... everything works fine (after a manual defrost & part replacement) until the freezer gets too cold (-10) and the fridge gets too warm (47)... this has happened multiple times at multiple intervals. i've replaced: evaporator fan motor, defrost heater, defrost heater thermistor, all thermistors in fridge and freezer and the main control board.  This happened to me again this past weekend and so i decided "let's replace some more parts", with 1 of which being the ice dispenser door/flap (it was icing up if i used it in the past). when i took the dispenser display/control assembly off, i noticed on the back of the circuit board that the 1 screw that held it in place actually screwed/dug into the board itself. it looks like it took out 2 or 3 pins with the screw, itself, showing signs of corrosion.  so my question to you folks is - could something like this, on this particular circuit board be the root cause of my temperature problems that i never would've guessed??? maybe it's shorting something?? causing bad ground??
i remember seeing on this forum once that someone had a similar problem and replaced the same parts as i did ALONG with his "fresh food defrost assembly" board under the assumption that THAT circuit board was causing problems for him. after all was replaced his fridge was working again but it wasn't determined what part really fixed it. (http://appliantology.org/topic/37379-monogram-ziss420drcs-side-by-side-built-in-frig-ff-at-42-deg/?page=2 )
thank you very much for any information or help you folks can provide! i really appreciate it!
-Walt
  • Replies 15
  • WalterP12
    7
  • Chat_in_FL
  • 16345Ed
  • AlboGator
Damper:
The fresh food compartment receives chilled air via an electronic damper that is positioned at the top rear of the fresh food compartment. The damper is controlled by the main control board and when open, allows the evaporator fan to push chilled air from the evaporator into the fresh food compartment.
Edited by Chat_in_RI
Yep damper good suspect.
Tell us about the procedure you used to replace the thermistors.
I ask because if those connections get comprised by moisture they could send bad data to the control board.
Edited by 16345Ed
19 minutes ago, Chat_in_RI said:
Damper:
thanks chat_in_RI for the response. i have actually JUST replaced the damper today also (in an effort to change all major components). i'm a little hesitant about that being the problem, though, because when i flipped the breaker to turn of the fridge and got to the damper it was in the OPEN position. that tells me the fridge had the damper open at the moment i killed the power, no? so it was "trying" to send air to that side.
thank you 16345Ed for your response.
I changed the thermistors by stripping and winding in wire nuts. then i placed silicone in the small gap in the wire nuts to "seal" them.
So i'm guessing you guys think the damage caused by the screw into the dispenser display assembly circuit board isn't a major culprit??
thank you again for your responses!
Ok, so was air passing through it? Is there a difference in air flow through the damper when the freezer door is opened or closed?
Thank you everyone! Replaced the damper and waiting on the display/dispenser assembly to be shipped (back order).  Will let you know how it goes.
Hi all,
Replaced the damper and the display/dispenser assembly and had my fridge running (for 4 weeks) like never before - it would actually stop running WAY more times during the day than it ever did and temperatures were holding great.  Now, I have a new, but similar, problem - i'm getting -7 to -9 readings in the freezer, but NOW my fridge stays perfect at 37. Could this be the thermistors in the freezer???
Thanks again for your help
On 10/29/2016 at 9:25 AM, WalterP12 said:
Hi all,
Scratch that.... ended up being the same problem... -11 in freezer, 45 in fridge.... so this time i tried a couple new mini experiments:
1. i threw some thermometers in the fridge and freezer. They were reading almost exactly same temperatures as the fridge was reporting back (-11 & 45)... so that leads me to believe nothing is wrong with the thermistors as you mentioned i changed above - looks like they are reading properly.
2. Then I jacked up the freezer temperature to 6 and lowered the fridge temperature to 34... doing so shifts my ACTUAL temperatures to -4 and 43... slightly "better" and closer to our nominal.. but clearly a delta of about 9 degrees on each side (from what is set, to the actual)....
so am i back to a defrost problem??? the only components that i have NOT changed yet are the "thermostat cutoff" and the Pan that's in there... do i need to try that icing kit?
or maybe it's NOT a defrost problem??... maybe i need another main control board or can it be the HMI board???.... running out of parts here, haha
Thanks again for all of your help!!
  • 3 years later...
I'd be very curious if you ever resolved this.  I've been having the same problem for years.  Have to manually defrost every few months.  Pls let me know, thanks!
  • 4 months later...
@walterP12
I am curious if you solved the problem too.
I am having the exact same problem where freezer stays at -10F and fresh food 46F. I have tried to replace the two thermistors in the FF which did not fix the problem (the new and existing thermistors have almost identical impedance readings); I tried replacing the damper assembly to no avail (again the new and existing damper have the same impedance readings).
The evap fan works OK: I feel strong cold air in the freezer -- there is an air duct in at the back of the ice maker, so I can feel it. On the other hand, I can feel cold air at the damper door when it opens, but air flow is not strong enough.
I am running out of ideas where to look. Can someone help?
  • 2 months later...
RE:  GE Monogram refrigerator side by side with icing problem, too cold in freezer and too warm in fridge
Anyone come up with a solution to this issue as stated in #37379?  I've been replacing parts but same problem.  I defrost manually then 7 to 10 days later freezer gets 15 degrees colder than I set and the fresh food side gets warmer than I set, usually about 15 to 20 degrees.  I am wondering if the problem relates to insufficient defrosting as I get no water under the compressor pan other than when I defrost.  Seems like replacing parts isn't the issue?  After defrosting I slowly get a buildup of ice and frost in the evap lower area.  The upper evap doesn't seem to get any permanent frost that I can see in the front anyway.  Seems like the icing of the evap slows airflow to the fresh food allowing it to warm up and the freezer to get much colder.
Thanks!
@Luv GE sounds to me like you may have a sealed system problem, (Low on Freon/R134a)
If only the lower part of the evaporator coil is frosting over it most likely never gets cold enough to close the defrost t-stat, (that is at the top of the evaporator coil), so when it goes into defrost the heaters never turn on.
The compressor just shuts off during the 20-30 minute defrost period then restarts without melting any of the ice built up on lower section of the coil then when the lower section is all plugged with ice not more airflow can get to the refrig section and the compressor runs constantly trying to cool thus getting the freezer colder.
