Need techsheet and wiring diagram Kenmore 106.57452701
Budget Appliance Repair
Manufacturer: Kenmore by Whirlpool
Type of Appliance: SxS Refrig
Model Number: 106.57452701
Kenmore SxS Refrig
Mod# 106.57452701
Ser# SU3939763 (10/2007)
Need the techsheet: 2303924
and wiring diagram: 2303928
  • Budget Appliance Repair
I was able to get the tech sheet, which only has diagnostic info but no schematic. And the wiring diagram PUB doesn't pull up on Service Matters. Try crossing over to an OEM equivalent model and I'll search using that.
Thanks, that will do, didn't have info how to enter diagnostics but figured out from similar models.
Bad damper, opened all the way and unplugged damper and refrig has been holding at 37 degrees till I can get the new damper.
Just wanted any of the tech info I could get to leave with unit where it should be but is missing.
