VMW washer "impossible" Failure Code
CoolTruck
Kenmore VMW Top Load High Efficiency Washer model 110.21302013 s/n C24730596
'Won't do anything'
Did pump out water, twice, after unplugged for 24 hours each time, then just a faint hum.
Failure Code #1 is F5 E1 (the 'Rinse' and 'Cycle Complete' lights are flashing)
Indicates Lid Switch problem but locks OK, filled to low and drained out two different times
Failure Code #2 is F2 E1
Indicates "Stuck Key on digital display" BUT this model DOES NOT HAVE the digital display!!
Failure Code #3 is blank
Failure Code #4 is blank
  • Replies 8
  • CoolTruck
  • lvasquez11
  • micabay
  • Lighthouse
Just now, CoolTruck said:
Forgot to identify the flashing lights for Failure #2 in initial post
'Won't do anything'
Indicates Lid Switch fault, but lid locks OK, machine filled to low level and drained out two different timesaver
Failure Code #2 is F2 E1 (the 'Wash' and 'Cycle Complete" lights flash
'Won't do anything'
'There are few atheists, inside a burning building'
It is "impossible" because we don't have a model number.
Lid lock could be wiring or board as well as the lock itself.
There probably is at least 1 button on the panel and it could be stuck or was held for too long.
Clear the codes and see what codes.
Where is the hum coming from? The pump?
  • 6 months later...
F2E1 - Holding down the start button for a long time while waiting for it to unlock...
F5E1 - Pressing start button while lid is open...
  • 1 year later...
I am having the exact same problems as listed in this thread. I have replaced the lid switch, the pump and the acuator and it still sits and hums and will not do anything when i try to wash. I can run diagnostic and it runs fills up and drains water and agitates but will not run for regular cycle. I do not know how to clear the codes. It will not run a calibration.
Well since you changed just about everything else... that leaves the board.
Sometimes calling a tech is worth it, lol.
