KitchenAid Refrigerator KSCS25FTSS02
lingroup
I have the KSCS25FTSS02 KitchenAid Refrigerator, out of the blue tonight it started beeping every 10 secs or so, when I open the door the lights go on and off and the display keeps flashing with different numbers.
Im at a complete loss as what to do or what's causing it. Any help would be appreciated.
small vine vid of it. https://vine.co/u/1412068236903759872?mode=list
  • Replies 7
  • lingroup
  • johntech
  • PlugNickel
  • abaesemann
i would suspect the main board shorting out since it controls the lights / display and would want to put my meter on it. Have you tried unplugging the unit to reset it?
I unplugged it for a min, that did nothing. By main board, are you referring to this board? https://www.repairclinic.com/PartDetail/Main-Control-Board/W10219463/1548001
It will be cheaper then buying a new fridge if that's the fix, unfortunately I have to find someone that selling it.
That board is NLA (no longer available), the repair is a service kit for the fridge with serial numbers starting with S and counter depth models only. You also may have to use a repair company to access parts and or repair.
  • 2 years later...
W10823803 was correct.  It is a tight fit as the new box is a shade bigger.  There is a tab on the top that is supposed to slip into a slot cutout.  No way.  I just bent it down as there are two screws mounting it in place anyway.
