Lg steam dryer
Mr app of Lex
Manufacturer: Lg
Type of Appliance: Dryer
Model Number: DLEY1701V
Trying to find a manual for this. I used the closest one I could find, but the buttons are different, so I can't get into diagnostics. Thanks in advance- DLEY1701V
  • Replies 1
  • Mr app of Lex
The DLEY12* manual will probably be close enough
