Frigidaire DishWasher
John in the OC
John in the OC
Howdy once again Boyz and Gurls
Today we have Frigidaire Dishwasher Model# PLD2855RFC3 That is acting up
The problems is when we close it will flash "PF" and the machine wont run
However if I push the cancel button and then push one of the wash selections it WILL START the wash cycle
Sometimes it will stay on and other times in the middle of the wash it will just stop and the panel goes "Black" or it will flash "PF"
The darn thing was really hard to close and my wife wasn't gentle with it when closing
Sometimes when I pull straight up from the handle while the door is closed and the machine is bolted in place and the panel is "black" It lights up with the "PF" flashing.
My observations at random times during the was when it shuts down is, while washing and something touches the door it will flash "PF"
Again I can get it to work by repeating to close it until it flashes "PF" then I hit cancel and select the washing cycle I wish
Sometimes it will finish the cycle sometimes it wont Sometimes when it stops it flashes "PF" and other times it does not.
Any kind of assistance is welcome
Thanks again
Sincerely
John
  • Replies 19
  • John in the OC
    11
  • john63
  • Hiroshi
  • johntech
Pf = power failure. Check all the wiring including the supply wireing and wireing to the board. May need new board if it is getting power when it pops up with the pf.
I would take a hard look at the door latch... if slamming the door seems to help get it to cycle- the door latch is before the control on the L1 power feed.
John in the OC
Yeah the latch seems to be a big part of it, The PF goes off and on when closing the thing. It just depends on how the latch sets when it closes...but what do I know thats why I am here
John in the OC
Groovy!
I really appreciate it!
Looks pretty straight forward. If I can replace the motor on a Frigidaire Ice Crushing motor This should be a cake walk
Thanks again!
John
John in the OC
Howdy!
I installed to a new latch! Seemed to work for almost a complete wash and then it started Flashing PF again...dang...
So do you think it could be the boards?
The thing closes a whole lot better now so she might be worth saving if the boards are not to expensive.
What do you guys think?
It ever sounded fixed...
John
Have you checked the wiring in the terminal box?
Not sure this will help but...
Back in the day when we were an authorized Frigidaire servicer...there was a customer with a new dishwasher (about 2002) with a complaint of "runs then stops" (control panel went dead).
The cycle could be selected again (control panel woke up)...but the cycle ended within a few seconds each time this was done.
The ground/earth wire was not connected at all.
After installing a wire nut on the ground wire...dishwasher remained on through the cycle.
Edited by john63
cracked solder connections on main board where multi pin plug goes in
solder the pins or change the board and your issue should be fixed
Edited by leamy
John in the OC
Howdy!
John
John in the OC
Howdy
I didn't open the board compartment, so I don't know if things are snapped or broken
The wires are all good!
I found a spot that has that board for 60bux I am gonna try it...
Everything is wired up correctly No grounds dangling or not secured
John
I think johntech and leamy are onto something...it would be a good idea to visually examine the Main Board for damage...
John in the OC
A giant capacitor is loose on the board...I didn't notice it before...I am really good at taking this thing apart at this point.
Sorry me no touchy capacitors .....I will wait for the board. Hardly works now
The capacitors on circuit boards of this nature are no worry touching them, unlike capacitors in microwaves or TV's.
If the lead/s on the solder side of board are just broken loose, get a solder iron and solder and redo the connection - most likely it will be all OK.   You really can't hurt it anymore and if it doesn't work, just replace the board.
when the cap wiggles the dc voltage drops and the board
ether reboots or dies.
Edited by leamy
John in the OC
Ehhh...Back in the day....early 90's I was working on an old PC ISA board.
Loose capacitor on the bottom of the motherboard So I tried to fix it, That thing fired off like a bullet and ricochet around the office like a bullet in a barrel.
It scared the sweet mother pearl out of me..
I retired my soldering iron after that.
I should get the part by Tuesday..
John in the OC
Well sure enough the motherboard was the culprit. Thanks again for helping me out with my appliance problems.
It closes better than it did when it was brand new now!
Something to be said about having a pro install these things. The little tweaks and tricks can save the customer big dough if you are not handy
These things are kind of fun to work on! Seem like there might be some money in this some where.
Pretty stoked about this one!
Thanks again
Sincerely
John
