Samsung dual element wire burnt
SAL
The dual element on my electric range stopped working correctly.  The outer 1" ring works fine.  When I took the glass top apart I found the blue wire where it connected to element burnt off.  I checked the element for resistance and I think it is fine.  Just wondering why this would happen.  Can I just solder the wire back on since the staycon male end is mostly gone?  I would love to add pics but don't know how.
Thanks for any help
  • Replies 5
  • SAL
  • johntech
  • certified tech group 51
Loose connectors can generate heat and burn up wires and terminals. I would replace the terminal. Not sure if there are any service bullitens we would need model number to check.
The male end of the connector ( the one attached to the element) is also burnt off.  That is why I was wondering if I could just Solder it.
Thanks
