KFFS20EYMS02 Service manual
SD40-2
Manufacturer: KitchenAid
Model Number: KFFS20EYMS02
Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES
Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES
Looking for the Service Manual for this KitchenAid 30 in french door BM unit please. Thanks.
  • Replies 8
  • SD40-2
  • Lighthouse
  • Scott-afl
Posted Images
I did a few wildcard searches on service matters and did not see a service manual
  • 2 years later...
I have a similar model, KFFS20EYMS00, that is not defrosting, or partially defrosting due to the harder rime ice i found. the defrost thermistor measures at 21.9kohms, but I don't know what the correct resistance should be, and the above tech sheet says there is a bi metal defrost thermostat, not a thermistor under the component specs, but in the wiring diagram, they show the freezer defrost evaporator thermistor.
So does anybody have the thermistor temperature resistance value chart for whirlpool?
13 minutes ago, EthanRanft said:
This is what’s been going around:DD5362CD-4151-44DB-B782-A3F9F1380D1B.thumb.png.0fdef40b91ce5219c4319adc833180aa.png
See if that is of help
tremendous help
thanks Ethan
