kenmore 70 washer tub not spinning 11024712300
thecapitan007
thecapitan007
topload washer tub not spinning, any ideas on what to check would be greatly appreciated, is it a motor or clutch. i can hear it trying to move the tub but it wont.
  • Replies 8
  • electro_doc
  • 16345Ed
  • abaesemann
  • thecapitan007
Does it agitate?  If so it could be the mounting block.Part number: AP6008836
You can remove the washer case and observe the action of the clutch and brake.  It is possible you have a problem with one of them.  Remove the case and jump the lid switch and put the washer in spin to see what is actually going on.
Doc
  • 3 weeks later...
Get eyes on the drive train. Could be the brake or the clutch. Could also be a bad coupling. Could also br the drive block i linked to.  You really need to open it up and get a look.
Or the neck of the spin tub is rusted out and it is making contact with the outer washtub... a sock between the tubs can also act this way. I agree that the cabinet needs to come off so you can see if the clutch housing is rotating...
Edited by Hiroshi
3 hours ago, 16345Ed said:
Lid switch?
if it agitates motor coupling ok.
Not necessarily true.  I've seen a cracked coupling work when it agitates but slip and not have enough grip to spin.  Rare but could happen.  He says it sounds like it wants to spin but won't for some reason, hence I don't think lid switch.I Still say you need to get eyes on the drive train to really get to the problem.
Doc
Doc
Fair enough, but I'd still test lid switch first. It's on top and easy to access.
