hardwick century series stove, nat. gas to propane
jettyby
stove is set up for natural gas, i want to use it with propane. On the top of the regulator there is a brass fitting, I flipped it so LP is up. what else needs to be adjusted?
  • Replies 1
  • jettyby
  • 16345Ed
Usually oven burner adjustment and different spuds on stove top burners. Should be conversion kit on unit somewhere.
