Linear compressor issues
Stronghammer
I have a LG LFX25976ST/00 and the new compressor (with new inverter board) ran for about 15 min or so just fine. Then the led light on the inverter board started flashing 3 times. At this point the suction pressure went up to about 20-30 PSI. I reset the unit. (unplugged till light cleared) and it would run without a blinking light but with the higher suction pressure. When i pushed the button to but it into test mode it would pull down for a couple minutes and then start blinking 3 times on the inverter board. I have the service manual but it only shows what codes are for 2,4,5,6,7 blinks. And yes I have made sure it is 3 times not 6. When it is in test mode the voltage to the compressor ramps up to about 300. when it is running but the suction pressure is high, the voltage is in the low 200's. It is the TCA36411701 compressor with the ABQ73004304 inverter board.
I am very confused about what is going on. Any suggestion would be appreciated.
  • 1 year later...
  • Richard Demint
  • Wayne Moore
  • Stronghammer
Sure wish someone would have answered this one. I’m having same issue.
  • 3 weeks later...
Richard Demint
Last one I worked on like this with a three blink was a connect error code I believe, check capacitor harness
