Champion D/W UH100B-70
16345Ed
No experience with commercial dishwashers.
Original compaint it was not holding water.
When I arrived it would not  drain the water.
How do I determine if it's the drain motor or the control. I'm not even sure how to access control board.
Any wisdom would be greatly appreciated.
Thanks
Ed
Edited by 16345Ed
  • 16345Ed
  • Hiroshi
Btw this design appears to have a diverter or something to switch from circulation to drain.
