      5
      All Appliantology tech members are invited to join in this workshop on all things Appliantological.
      We have a special session planned for this one. Instead of the usual Show 'n Tell on a technical topic, we're going to post tech sheets in the comments to this Calendar Event (scroll down to see what's posted so far) and ask specific questions that can only be answered by reading the tech sheet. If you at least try to answer the questions beforehand, you'll get a lot more out of it. The tech sheet and the questions are posted in the comments section below.
      Your mission, if you should choose to accept it, is to check out the questions for each one and try to answer them ahead of time. Then come to the Dojo to see how well you did!
New Appliance Service Manual added: Electrolux Service Flash RF1602 - Warm Temperatures in the Fresh Food Compartment of French Door Bottom Freezer Refrigerators
ss120396
View File
French Door Bottom Mount Refrigerator
Frigidaire, Electrolux, Crosley
E23BC68JP E23BC68JS EI23BC30K EI23BC36I EI23BC51I EI23BC60KS EI23BC80KS EI27BS16J EI28BS36I EI28BS51I EI28BS80KS FFEG2322QS FFHB2740PE FFHB2740PP FFHB2740PS FFHN2740PE FFHN2740PF FFHN2740PP FFHN2740PS FGEB28D7RF0 FGHB2866PE FGHB2866PF FGHB2866PP FGHF2366PF FGHN2844LE FGHN2844LF FGHN2844LM FGHN2844LP FGHN2866P FGUN2642LE FGUN2642LF FGUN2642LP FPBG2277RF FPHG2399MF FPHG2399NF FPHG2399PF FPHN2899LF FPHN2899PF LFHB2741PF LFHN2741PE LFHN2741PF LFHN2741PP LGHB2867PF LGHN2844ME LGHN2844MF LGHN2844MP CFD26SDS CFD27SDPS CFD28SDQS CFD28WIQ DGHF2360PF
Serial range: 4A436xxxxx to 4A527xxxxx
Customer complaint: The Fresh Food Compartment is not cooling sufficiently, particularly on the top right shelf, mainly when shelves are heavily loaded with food and containers.
Link to comment
  • Replies 0
  • ss120396
