Trouble Saving Content
KaveMan
Was wondering why I can download a document from the tech manual forum, but site won't allow me to save it to Dropbox. I get an error code every time...is it my settings in IPad or a feature of the website? Thanks...
  • KaveMan
  • LI-NY Tech
  • Joe B, Stoughton Appliance Repair
George,
I've never seen a direct option to save to dropbox, per-se.  I always select download from the pop-up window and the file opens in a browser window on my mobile device (iPad).  Then I import/save into dropbox etc.  On a laptop, the download button saves to a local folder, then I move the files to dropbox.
Either way it's a two-step process, but it does work.
Do you have a different process?
That's the process I use, SAR, but get an error code every time telling me to check my internet connection...which is always fine.
Once the file is downloaded to your device you can do whatever you want with it.  If there's a problem uploading to Dropbox it's likely a problem with your device.
