Samsung RF28HDEDBSR 23E Condensor Fan Error
jgoldeneyes
jgoldeneyes
Hello All,
I have a Samsung RF28HDEDBSR refrigerator that I have been working on. I have replaced the C fan motor and I still can't get past this error when I plug the fridge in. I have the service manual and I went through all the troubleshooting steps for this error / problem. I am getting the right voltage to the right pins. I even verified that the fan can spin by giving it 12v from a separate power adapter. I even verified that the 12v gets to where the motor plugs into on the housing. Is there something I'm missing? Any help would be appreciated.
Man that's a tough one.
Do you get 7 to 10 VDC at fan connection with it connected?
or did you disconnect and test the voltage?
Edited by 16345Ed
Richard Demint
11 hours ago, jgoldeneyes said:
Hello All,
Did you give it the 7 minute delay? Whats the ambient? Page 86 in manual will give you more info but you could be looking at a main board.Also check your harness connections, both sides. I have had several of these that were having an intermediate ground issue for the fans. In that case I would rewire fan ground at main board to known good ground.
jgoldeneyes
I gave it the 7 minute delay. Ambient is about 72 I also put it into FF mode which is like a manual mode to make sure the compressor came on. Forgive the ignorance but what do you mean by harness connections? Also how would I go about rewiring the ground?
jgoldeneyes
I did disconnect the fan to test the voltage. Got 11 VDC
Richard Demint
Did you check your pulse voltage like on page 86?
Harness connections sorry should have cleared that up, you can unplug connections in multiple places like at the main board, under hinge covers,ect.
On the ground problems I was experiencing, Did you check to see if you had ground at fan? if you do, you do not need to worry about this.
I suspect either no ground or no pulse width modulation.you said you had the service manual, on page 86 it will tell you all of this.
I'd test for voltage with circuit complete (connector plugged in). See if any difference.
jgoldeneyes
Ok update people. I am not getting 12vdc to the fan with it plugged in. Only getting around 2 -3. Also I checked all the pulse voltages and I am not getting the pulse voltage on pin 9. The fan does have ground btw. So you think I should just replace the main board PCB? Or could the problem lie with one of the other boards?
Did you say you were getting 12vlts without the fan hooked up?   I so it would be a bad fan loading down the dc circuit.  You would need to replace the fan.
Doc
jgoldeneyes
Doc
Already replaced the motor in the fan. I verified the fan can spin while in the fridge by supplying 12v to it from a power adapter.
You need to unplug other DC loads one at a time from board and test for voltage at the condenser fan. Until you find load that is loading it down. Probably evaporator fan...
Edited by 16345Ed
That sounds like good advice ED.  I wouldn't have thought of that although he did say he already replaced the fan, I missed that.  I'm with you. Curious to see what is found. Does sound like the evap fan is a good suspect.
Doc
Richard Demint
Replaced the motor in the fan? Meaning same housing?
Richard Demint
is the voltage between main pcb ground j23 jumper and cn 76 "5" ( sky blue) around dc7-12v? no----- external temp above 66.2degrees?--yes----does dc 7-12v alternate with below dc 2v between main pcb GROUND j23 jumper and cn76 "5" (sky blue)?---no----replace main pcb ground
Not sure what pin 9 you are talking about? What service manual do you have?
jgoldeneyes
I'm sure it's the same one you are using https://drive.google.com/file/d/0B5cn84h7OzSjc2xESS15TXZRd1k/view?usp=sharing Underneath where it asks if DC 7-12v alternate with below dc 2v between main pcb ground j23 jumper and cn76 "5" (sky blue) There is a reference box that talks about the pulse signal and it states that cn76 7(F Fan) 8 (R Fan) 9 (C Fan) will generate the pulse signal when the motor rotates. I am not receiving that pulse signal at cn76 "9"
jgoldeneyes
I unplugged both evap fans and something is still loading me down. How many other DC loads are there?
Richard Demint
 I see it, my apologies.
Ok so is that a yes or no with if dc 7-12v alternate with below dc 2v between main pcb ground j23 jumper and cn76 "5" (sky blue)? If no  and I am reading this correct it says to replace main pcb ground.
I would trace the actual wires from fan to board and start testing that way first before I bought the board. i`m not sure how you are testing for ground but using that jumper you might have it there but not at the actual wire. start tracing the c-fan wires down,Test the positive pin at fan and hold your neg. on a known good ground at board and see if you have your 12 volts.
rbmappltech
I had a similar problem this last Friday,  I found  a 500 ohm resistance between the plus and minus of the fan itself. Determine it was a internal wiring harness problem,  a really werid problem,
jgoldeneyes
45 minutes ago, 16345Ed said:
Where are you unplugging them?
do you not have fast track?
I unplugged them at the fans themselves. I don't know what fast track is.
You have service manual. Pull up schematic and determine your DC Loads. Unplug them from board one at a time and see if condenser fan ever gets full voltage. Could be ice maker... or anything like that.
jgoldeneyes
For my particular model I can't unplug individual loads at the board as there are multiple loads per connector. If I pull one connector out I could be pulling 4 or 5 things at the same time so I wouldn't be able to find the culprit.
  • 2 years later...
What ever happened here.  I have the same problem today.  This is the second Samsung refrigerator giving me the same problem.  I followed all the same steps here.
Just curious, have you tried the force mode step 1? It turns on all fan motor and force the compressor to run at 100%.
