Viking Fridge Demo mode
Helpless110
  • Replies 4
  • Econo Appliance
  • dgirton
  • MoTeD
  • Nathaniel Peterson
Cannot look up Viking parts without complete model and serial, especially the hybrids.     Give us some info or a picture of label to start with.
You can try unplugging the unit. Plug it back in and Press and hold freezer up and fresh food down while it is powering up.
Removing power does not exit demo mode on refrigerators. It is used in showrooms to allow retailers to flip one switch to turn off all refrigerators. I believe this unit was manufactured by Whirlpool. Has OP tried calling VIKING?
I have found this on a similar model. Follow at your own risk.
Show Room Mode Enter or exit the Show Room Mode by performing the following sequence of events: 1. Press and hold the DOOR OPEN ALARM button. 2. Press and hold FREEZER TEMP UP button. 3. Release the DOOR OPEN ALARM button and wait 3 seconds. “SH” appears in left display. 4. Press the FREEZER TEMP UP button again. “On” or “OFF” appears in right display. 5. Press the REFRIGERATOR TEMP UP button and REFRIGERATOR TEMP DOWN button to toggle showroom feature “On” or “OFF”. NOTE: Showroom will always be off when first powered up. 6. Press the FREEZER TEMP UP button to confirm setting. The display will flash the selected setting.
Other than that I would call VIKING and have one of their service techs come out. If nothing else it is worth having a tech out for the cost of a service call.
  • 1 year later...
i need a service manual for this refrigerator please
