Kenmore Washer SERVICE MANUAL REQUEST
samedayapprepair
Manufacturer: KENMORE
Type of Appliance: WASHER
Model Number: 41741100000
Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES
Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES
Hello,
I am working on a front load Kenmore Elite washer Mod# 41741100000 Ser # 4C41404838. The problem with this unit is the machine does not turn off itself, have to turn off water supply manually. Unit does not drain water as well. Has anybody come across this problem, i am open for suggestions and solutions.
Thank you!
Link to comment
Sorta sounds like a pressure switch failure or a hole in your pressure tube- if the unit cannot measure a full tub it will keep filling until the switch is satisfied, and if it has no water level registering it will not run the pump on an empty drum...
Here is the Frigidaire cross pending approval...
Link to comment
That file was already in the Downloads section so I replaced your upload with that. But domo for identifying the correct manual!
Link to comment
  • 2 years later...
2 hours ago, MVrepairs said:
That is a dryer manual.
You're right, MVrepairs! I replaced the link with one pointing to the correct tech sheet for this model. Thanks for pointing that out!
Link to comment
