PSH23PSRASV GE Profile refrigerator compressor won't start
K Seeley
Voltage from the motherboard to the inverter board was measured at 7.8 volts.  Per your youtube video, you expect 4-6 volts.  Does 7.8 volts indicate a problem with the motherboard?  Overall behavior is that lights/fans, water dispenser are all working.  On applying power, there is a clicking for about 3-4 seconds, but the compressor doesn't come on.  I've yet to remove the inverter board to test resistance between the compressor contacts.
Thank you.
The 7.8 v would not make me think the main board has failed. It is high but if I had speed signal voltage around 3-7 vdc, 120vac supplied to the inverter and the compressor pins ohmed out the same and are not grounded I would replace the inverter.
