Ge GTDP490EDOWS new timer not stopping
Mark Niswander
Mark Niswander
Just replaced new timer same results,Put  on delicates goes past stop and stops on timed dry 70.Also will stop on wrinkle care before the end.So when use timed dry start at 65.
  • vee8power
  • Mark Niswander
  • igloo
Is your timer knob cracked where it goes onto the timer shaft?
Edited by vee8power
  • 2 years later...
Any solutions here? Dryer stops early on timed dry normal heat with wrinkle care on.
GTMP280ED0WW
Edited by igloo
added model #
